Building your own ROM
sellers86
1,837
617
alright it finished compiling. but no .zip. do i have to zip it all up?
EDIT: I zipped it up and get a huge .zip file. Its like 565 mb. What happened haha?
asadullah
480
182
I haven't done a build for ever, but isn't there an option to build all devices? I was wondering if you accidentally selected that instead of the ov
It would still make a system.img it looks like mkyaffs didn't work correctly make sure you run
Code:
make clobber && make clean
JerryScript
Daydream Believer
Mar 8, 2011
2,055
1,559
Some say warning then i cant catch the rest because it goes to fast. heres one i got on a screen shot.
I posted about that error a few pages back. You might want to research this thread a bit to see how we work around certain peculiarities when building. ;)
The omap error is fixed by applying the following fix, you want to add the + line (removing the + of course):
Edit- look for this code segment in /build/core/pathmap.mk
Code:
FRAMEWORKS_BASE_SUBDIRS := \
	$(addsuffix /java, \
	    core \
	    graphics \
	    location \
	    media \
	    opengl \
	    sax \
	    telephony \
	    wifi \
	    vpn \
	    keystore \
	    voip \
+            omapmmlib \
Let us know if you get other errors, let us know what they are, and we will try to help.
Patience is definitely one of the keys to building Android! ;)
sellers86
1,837
617
Code:
	    core \
	    graphics \
	    location \
	    media \
	    opengl \
	    sax \
	    telephony \
	    wifi \
	    vpn \
	    keystore \
	    voip \
+            omapmmlib \
How do I do this?
sellers86
1,837
617
Sorry, I left out the filename: /build/core/pathmap.mk
Look for the section I posted above, and add the line with the + (leaving out the + of course). ;)
Note- I edited the above post so others won't be confuse.
I went and find the first post and based it off that file. as far as i can tell its working because the make bacon is taking a lot longer. ill reply back to see if it worked.
sellers86
1,837
617
It worked. First build is done. It came out with 2 .zip files. which do I use the cyanogen or the IHO or are they both the same.
ajones23
54
8
Im having some trouble getting started. I have ubuntu installed,and java,and android sdk. But still cant get it to work once booted into ubuntu.
JerryScript
Daydream Believer
Mar 8, 2011
2,055
1,559
The update zip with the corresponding md5 is the optimized one. You can use either, but the optimized one of course performs better and is smaller.
AmeliaRodriguez
