Problem with Wallpapers. iho/ics
theforerunner
69
3
I noticed on IHO backside and even on this ICS Final rom, which i believe is actually part iho, that you cant set the wallpapers to the correct size. in fact it makes it way too far zoomed in which makes the image look all pixely and crap. I know if i could figure out where the wallpaper file was in the rom i could just move them to my gallery and change it that way, but is there an easier way than that ? some "settings" option i am missing or something?
anthonycr
Themer. You've seen them
Jul 11, 2011
2,104
571
Well your right about the ics rom being iho... I really don't know how there can be a problem with wallpapers... they are built into the cm apk and so you would have to take it apart to fix this problem. Post a screenshot to show exactly what's going on.
CuriousNoob
Banned
Aug 2, 2011
1,590
202
Use Quickpic to set wallpapers. The problem is the Gallery, as I suppose not much work was put into it...
tress
