01-05-2016 05:35 PM
2,975 ... 8788899091 ...
tools
  1. jonny5449's Avatar
    Just a heads up- Google Ears, Google's Shazam-like widget implemented in Jelly Bean, is now up for grabs on ICS. It appears to be fully functional and you just have to install an apk. It's over at XDA, if anyone is interested (I don't think we can post links to other sites, right?).
    I do a lot
    Sent from my LG-LS670 using Tapatalk 2
    08-16-2012 07:30 PM
  2. inceyet's Avatar
    I downloaded the file on http://getquattrimus.com/ but comes up with a folder with 3 files which one do I put in to my phone.
    http://androidz.jimdo.com/lg-optimus...-lg-optimus-v/ What file do i need to change to put ics on my lg optimus v.
    I am not trying to be rude but these type of ? Need to be directed to the right tread and if your asking those ? You shouldn't be flashing this rom just yet you need to get your feet wet first before you jump in the deep end. This tread is for the development of ics bug reporting fixes etc. not how to
    Edit: you shouldn't be unzipping those files at all you might erase something by accident
    08-16-2012 07:31 PM
  3. terthii's Avatar
    I do a lot
    Guess I'll post a link later then.
    EDIT: Just added the link!
    inceyet likes this.
    08-16-2012 07:49 PM
  4. akaEgg's Avatar
    Witch 1 are you on CM9 or AOKP
    AOKP. im downloading the cm9 one now.
    08-16-2012 07:58 PM
  5. akaEgg's Avatar
    Did you do a clean install?
    Formatting system, data, boot, sdext, cache, and dalvik cache?
    sent from my Zom-"Bean'(CM10 JellyBean).
    all i did was backup, wipe data/factory reset, and wipe dalvik cache. Should i use a different recovery? because im not to sure what sdext is. im using CWM-based Recovery v4.0.1.5
    08-16-2012 08:01 PM
  6. kobequintana's Avatar
    OK when you finish flashing and have your account setup etc. Go to settings performance than processor and change the CPU to 480/600 interactiveX than that should fix your rebooting problem
    akaEgg likes this.
    08-16-2012 08:12 PM
  7. akaEgg's Avatar
    okay thank you. Now what exactly do i need to wipe? All ive been doing was wiping the data/factory reset, and dalvik cache
    08-16-2012 08:26 PM
  8. kobequintana's Avatar
    When switching from AOKP to CM9 I did a dirty wipe (only wipe cache and delvik cache) but I thing a clean wipe (Wipe every thing but SD CARD pretty sure you know that) is recommended
    08-16-2012 08:37 PM
  9. akaEgg's Avatar
    i did a clean wipe and changed the cpu. it seems to be working fine.. except for the play store when i open it it says "server error" i hit retry but it doesnt work. Do i need to reflash the gapps?
    08-16-2012 08:57 PM
  10. kobequintana's Avatar
    Is your 3G on
    08-16-2012 09:02 PM
  11. akaEgg's Avatar
    Is your 3G on
    negative. i dont have service at the moment. ive been using wifi. :I
    08-16-2012 09:04 PM
  12. kobequintana's Avatar
    OK than try to reboot
    08-16-2012 09:05 PM
  13. akaEgg's Avatar
    it worked. but when i rebooted the cpu reset itself. What should i do about that?
    08-16-2012 09:14 PM
  14. akaEgg's Avatar
    i have another problem. when i try to download something from the play store an error screen pops up and says "Error processing purchace. [DF-BPA-13]"
    08-16-2012 09:19 PM
  15. kobequintana's Avatar
    http://forums.androidcentral.com/sho...d.php?t=200757
    This will help
    08-16-2012 09:22 PM
  16. capslock118's Avatar
    I don't have it on me but I read a different thread on xda that said to just turn off sync on your account, turn it back n, then reboot. That method has worked every time for me.
    08-16-2012 09:47 PM
  17. tmanrules's Avatar
    Should I follow this video.
    [YT]http://www.youtube.com/watch?v=ThQfHC3vpRs&feature=related[/YT]
    08-16-2012 11:50 PM
  18. kobequintana's Avatar
    Yeah
    08-17-2012 12:10 AM
  19. sellers86's Avatar
    Again?... just flash it like a normal rom.
    Sent from my VM670 using Tapatalk
    08-17-2012 12:11 AM
  20. inceyet's Avatar
    Once again you really need to direct these questions to the appropriate tread let's keep on topic cause evidently your not listening to anybody and your gonna do whatcha wanna do.
    tdm likes this.
    08-17-2012 02:30 AM
  21. Ryuk6666's Avatar
    Yo guys!!!! Haven't been here in a while!!! (School and marching band for me pretty busy this past week xD) is beta 2 still the latest and greatest?
    Sent from my A.C.R. Zombified Quattrimized AOKP OV.
    08-17-2012 03:18 AM
  22. inceyet's Avatar
    You know it plus tdm is dropping a multi phone rom
    08-17-2012 03:49 AM
  23. blizard's Avatar
    I don't know how I did it but I went to set a SD partition an my phone completely stopped working wouldn't even boot had to factory reset an format my SD but fixed now just lost all my stuff
    08-17-2012 05:16 AM
  24. andrewnelson23's Avatar
    That's what happens on a partition. You should have known what you were doing before you did it.
    So I just moved back to college, where I actually have 3G! woot! But I'm getting TONS of freezes and such now....Tried changing up my cpu and everything, but still freezing a lot. Also, my browser just keeps closing. Doesn't even throw up an error. Anybody know anything about this?
    08-17-2012 09:53 AM
  25. terthii's Avatar
    CM9 or AOKP and what version?
    08-17-2012 10:07 AM
