ThatGuyLurkin
Well, I guess it should be a bug report anyway. If you switch your lockscreen style to Honeycomb, the option to unlock it and any other shortcuts on there completely disappear. Just tried it and sure enough, it happened again and I had to unlock by going to settings in the notification bar.
Honeycomb works perfect for me. Honeycomb never had shortcuts though, did you set any?
