sellers86
Another thought I had was to make hybrid roms.
The only differences in roms between the thunderc models are:
boot.img
system.prop
Mms.apk
If I can pack up all versions of each of these and create a script to install the appropriate file set at install time, that would reduce the traffic by almost 2/3.
And if I can find a way to build template versions of these and replace the values after the build, that would reduce the build time by almost 2/3.
How would you be able to make it tell which phone it is? Do you think you could write a script for it? Sounds extremely difficult to me lol
Sent from my VM670 using Tapatalk
