[ROM][BETA] Quattrimus ICS
Delta updates are just the files that have changed.
Sent from my LG-LS670 using Android Central Forums
It's a physics term, and probably other high level math as well. It means change. You answered the question, but I thought a little etymology might be nice. :)
Reactions: brotherswing
@tdm so when are the nightly deltas going tp start
Someone asked a few pages back about DSP manager on AOKP. I got it working tonight. I took the files from the CM9 build. I took the DSP manager apk from system/app then libbundlewrapper.so and libcyanogen-dsp.so files from system/lib/soundfx and for good measure AudioFilter.csv from system/etc. Place the files in the same folders in the AOKP ROM. You may need to change permissions for the DSP apk after you place in system/app folder. Reboot. After phone boots back up, go to system settings, sound, music effects and choose DSP manager.
Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
Tdm awesome from, but nightly 07/19/12 is causing me a lot of reboots and freeze. And is slower than 07/18/12 hope it fixes by next nightly or delta. Thanks for everything :D
Aokp or cm9?
And what are your clocking speeds and governor, and did you install any performance tweaks onto of the rom?
sent from my un-dead sammich
I have an old version that doesn't auto update. Nor does it have syncing problems on gb rooms.
Could you send me a link?
And when was the last time you used it?
Every Netflix app that has update checker disabled, still asks to be updated. And have you tried it on quattrimus?
and what version is the app?
I've tried all of the xda Netflix apps, from version 1.2.1 to 1.8 and none have worked on any roms without requiring them to be updated. And even then, in all of the GB roms (all IHO) had sync issues.
I'll dig it up from one of my backups. It still asks you to update but it never forced you. It worked on Jerry's iho. Never tried it on cm9 but I doubt it works.
Yea I remember using one on BACKside that didn't ask for updates up till ~april or may, and then it started asking for updates, even though it was one that had update checker disabled. I pressed back when it asked for the update, but it would either close Netflix, or be stuck at a grey screen. It was 1.1.7? I think. And it worked flawlessly until Netflix changed the way the apps checked for updates, which renders any and all old work arounds useless, and forces you to update.
Froyo roms are currently the only way to watch Netflix without issues.
GB has sync issues
ICS only plays audio, and if video does work, there's sync issues.
Anyone else getting an "Error Processing Purchase" when trying to download apps from the Play store?
Another thought I had was to make hybrid roms.
The only differences in roms between the thunderc models are:
boot.img
system.prop
Mms.apk
If I can pack up all versions of each of these and create a script to install the appropriate file set at install time, that would reduce the traffic by almost 2/3.
And if I can find a way to build template versions of these and replace the values after the build, that would reduce the build time by almost 2/3.
Fletch1998
