nitestalkr
I'm wondering, is Deep Sleep back?
AFAIK, deep sleep is working in AOKP, and I think in CM9 as well.
Someone correct me if I'm wrong.
sent from my un-dead sammich.
What is deep sleep?
Song Of The Week
Song: End Of The Dream
Band: Evanescence
Album: Evanescence
https://www.youtube.com/watch?v=GdSIaDv7K74&feature=youtube_gdata_player
What is deep sleep?
Song Of The Week
Band: Evanescence
Album: Evanescence
Does anyone else's clock get out of sync? Seems like it only updates after 10-20 seconds after I unlock the phone.
This is a known bug with no known fix.
There is a fix, its been explained multiple times. Download clock sync from the market, go into its settings and change refresh rate to 30 seconds and check strict intervals.
Alright. I only ask you or anyone questions if a Google search returns nothing. Just my two cents and I appreciate all the work you and every other devs do.
I get "Unfortunately, Clock has stopped" error messages on the initial unlock after rebooting, when I tap on the face of the clock, and when I go into the clock app and try to set an alarm. Is this related to the sync issue, or something else? (I've just installed that ClockSync app and set it as instructed, but I'm still getting the error message.) CM9 Beta 2 (working very nicely other than this).
Hey,
I am learning too, so I added you on facebook just now. Feel free to ask me and if I know, I'll be glad to help.
Rob
Wouldn't that kill battery more?
I hide lock on status bar anyways
Where is systemUI.apk located
