No screenshots, sorry. Unplugged my phone at about half past noon on Sunday, left it on and unplugged until about quarter to two this afternoon. I have no reliable battery monitor app.
Sent from my Quattrimized Abacus.
Anyone know how to get dsp
Will this ROM get an updated kernel like Bobz? I can overclock on his latest release, but not on CM9. Need offline charging or I'd stick with BobZ CM9.
Anyone know if any new nightlies r coming
Sent from my LG-VM670 using Xparent Pink Tapatalk 2
Not until jb. CM9 is baked. The next ics build will be a multi rom, and there might be a couple more fixes in it.
Do you have an extended battery?
I see no way to survive 2 says using 3G on ICS. ICS battery life is worse than GB. Especially with these deep sleep issues
I could see 48 hours with no charge with like 0 usage of the phone maybe.
Hi guys, I have a persistent issue with cm9 (quattrimus, bobzhome, CAI). I've tried them all and the same issue comes to the surface. Every time I leave my phone unattended for a while (off the charger of course) it will enter a comatose state ( black screen, and no buttons responding ( power key, volume rocker, camera, the one next to the camera, menu, home, back and search)) and the only way to get it going again is to pull the battery out and back in.
Does somebody else struggles with the same issue? And.if you are not sure, try leaving your phone on overnight without the charger plugged in. Also silent mode, set an alarm, wifi and BT off.
I would really appreciate feedback on this because its the only thing making me go back to cm7
Thank you for taking the time to read this.
Since you brought it up, are you paying any attention to the Jellybean work that BobZhome is doing? Looks like he has something somewhat stable at this point. Maybe there are some fixes that would be useful to bring over to the ICS Quattrimus roms?
forgive my noobishness I'm trying to learn, what is multi rom exactly
I see this every once in a while. When it happens I Just push the power button one more time and leave it alone.
It either wakes up after a moment, or soft resets.
i have done this but dsp doesnt do anything when i turn ob bass boost or equalizerPull from another rom , place in /system folder and change permission to rw,r,r
Reboot
Sent from my LG-LS670 using Tapatalk 2
Has anyone else been able to reproduce his mileage? 48 hours is quite a feat.
