cole2kb
Retired Moderator
There isn't much detail on the remaining bugs (for LS670). Would somebody please tell me how bad they are?
1) HQ video. Can I watch SD YouTube videos no problem?
2) Deep sleep bug/power drain. How bad is it? How much less battery life relative to GB ROMs?
3) Clock lag. Would my phone likely becom unreliable as a timepiece? As an alarm clock?
4) Random reboots. Roughly how frequent (on an LS670)?
A note on the alarm clock -- I haven't had any issues with it missing my alarms, even if the time itself doesn't update. I don't have ClockSync installed, but I do not use the built-in alarm clock, I use Alarm Clock Plus from the Play store. (Awesome app, btw.)
Tasker should be able to do that, though it's not a free app...
The phone should do this automatically, but OP's question was vague.
Do you want 3G to turn -off- or just the phone to switch to Wi-Fi? As long as you have Wi-Fi turned on, your phone should connect automatically to a known network within range.
