Is AOD onAll those notifications are OFF except for text messages and calls.
Strange ..youll have to dig little more deeper into that battery app if you can find something
How much does yours deep sleep?Strange ..youll have to dig little more deeper into that battery app if you can find something
I never tested it out , I usually get very good battery life but I can report back in 24 hours let you knowHow much does yours deep sleep?
Never tested , OP didn't respond I should test it.What have you found?
Sorry for the delay. Let us know the results.Never tested , OP didn't respond I should test it.
Ok, I'll start tommorow 24 hours from thenSorry for the delay. Let us know the results.
Im on Att ,brightness on auto ,signal is weak at work but have wifi so I would say 50/50 on LTE and wifi and AOD AOD schedule from 7am to 10pmWhat are your AOD and signal like for this? What network are you on? What is your screen brightness and other setting like?
