AndroidCentral won't let me post since I don't have 10 posts, but Google search for Phone Arena review Note 4 and check it out!
Seems like every review, including this one, can't figure out how to set up the finger print reader. Is it really that hard to figure out to scan your finger from 10 different angles instead of the same angle 10 times? Seems like common sense to me, and think I saw that the software on the note 4 even suggests this during setup if you read what it tells you...
Don´t trust the higher FPS of the iphone 6+.
The benchmarks were not ready when phonearena did the test and they are rendering at 640 x 1136 during the on screen test (the resolution of the iphone 5s) instead of the HD resolution of the iphone 6+ (nearly 3 times higher).
Therefore the big difference in FPS.
I told phonearena several times to correct those values, but it seems there is no one listening...
