WeAreAllUnique
I changed the data cable and now it seems to be working every time. Using an old cable from the Note 1.
Note in my house!
Note in my house!
It could be a software problem.Well at least I know the problem now. All cables i use fast charging or not are showing up as USB charging regardless of Whetter I have it plugged into.
Does anyone have a solution for that?
For me it was the cable. Once I changed it to another one I haven't had anymore issues.Update: this is crazy I'm on the new phone and now it just started the slow charging again. I only use the Samsung charger and Verizon charger unless I'm in the car but because I have 2 batteries I rarely have to charge it. Has anyone else had this problem? I don't know if it is an app doing this or what. I wipe it completelyand it doesn't help. What's the odds of getting 2 phones back to back like this?
When I did a soft reset, the unlocked sign was showing at the bottom of the screen before it came back on. Like if the bootloader was unlocked.
Note in my house!
I haven't replaced the phone. I just replaced the cable.Did your phone go back to normal or did you have to replace it
Note in my house!
What's crazy is that I'm only at 23% and I took it off the charger at 830. I'm a heavy user and it seems like in the past my phone would have had to switch batteries by now. Maybe it's just in my head. I'm about to play a game and really find out.
