Hi guys, my air-command suddenly stopped showing-up when I remove S-pen or when I press the button.
S-pen is fully working tho, I can write, the hover information shows up, and I can use button to highlight text.
S pen sensor is working, too, as when I remove it, it makes sound.
The problem somewhere in system, as I can not do anything in air-command tab in option menu (see picture)
As you can see, the menu is shadow, so it doesn't allows any interaction whatsoever. (Not possible to scroll down, that's it)
Do you guys know, what to do with that? Possibly if you know how to reinstall drivers or do you think that factory recover would fix it?
Thanks for ANY reply.
