a Note 4 SM-N910F, Android 6.0.1, BB N910FXXU1DPE2, kernel 3.10.40-7733605 dpi@SWDD6721 #1
i feel I have tried everything... History:
Phone has been working fine for a year, upgraded to 6.0.1 no problems about 2 or 3 months ago. no new apps installed. Last week it started getting very laggy, keyboard strokes took for ever to register. I thought, ok, time to to a factory reset to blow out any old cobwebs. Did it via the menu. However the phone froze midway thought. I left it for an hour and then pulled out the battery. I popped it back in and it performed the reset without me having to press anything. Cool, thats good I thought.
Now I was going to change the battery, so I powered off as normal and put my other 2 week old original samsung battery in, and it would not power on. After a few reinsertions it powered back on. I though i have to do another reset. So I tried, and it would not reset. It just died. I cant restart the phone, it dies. If I shut it down normally. it wont turn on back on, I have to take out and reinsert the battery multiple times, holding down the powerbutton between to discharge. this can take up to 10 tries now. Sometimes it will go th the unable to bot in normal mode and "downloading , do not turn of target, but it will stay there for ever, more than an hour.
Every 15-20 tries it would turn on, let me get in via pin, only to start freezing up within a min, and then die again. Somewhere I read that a guy hada similar problem, and he used wakelock and that worked, on level 4. I managed to download that and used it, and hey presto, it works!
Now I had to power down the phone for a reason, and it took me about 30 min of battery and powerbuttonholding before it managed to boot up, and I was quick enough to start wakelock on level 4.
It wont boot in to safe mode, it wont boot in to recovery mode, it wont boot in to the factory reset mode. Its the same with either battery, and different cables.
Any ideas what i can do here, or what could be wrong? I havent gotten it wet or banged it.
