Note 5 Battery life thread
pwiddy
21
Not pleased so far....To Say The Least
spasell
584
This is irritating me. Look at the Android system usage. Total use not great either. Again I think it's combo of WiFi and Cell on Verizon causing issues.
Kelly Kearns
8,729
6
A couple times I have charged overnight with the furnished cord. In the morning I am only at 90 or 92%. How do I get it to charge to 100%?
The furnished cord should do it and do it on fast charge, it shouldn't take long to charge it to 100%. If the cord isn't working correctly, I would send it to Samsung and let them send me a new one.
AlexMarie15
111
I plan on putting it on the charger when it drops to 20% to limit my excessive use of it, but the battery life on this thing makes me so happy everyday, especially coming from the note 4. Even with heavier usage than I had with my note 4, the note 5 just lasts for my usage.
MedicD
286
That's pretty bad. Verizon?
Your issues are from:
- cell signal is exceptionally low
- Google Now/Frequent location updates
- Are you using Google Wallet by chance?
How do I know? Looks exactly like my issues. I found a way to reduce a large amount of it, but in the end, I'm always near a wireless charger so I started caring less.
Some people report turning off Advanced Calling fixed all their issues, but I didn't see a difference.
wottankes
I having a problem whit my it's look like the battery is drawing fast, I have to charge it 2 time at day
Sent from my SAMSUNG-SM-N920A using Tapatalk
pwiddy
21
Yep, Verizon....cell signal I can't change but yea I am sure that has an impact, although never noticed it with other phones.
The location thing is interesting because a lof of the time when I unlock phone, it shows finding location...guess I will try google now off and see hwat happens. not using google wallet and I actually like the HD calling feature...thanks for reply
I was getting comparable battery life from S6 just last week.
John Adam1
I came from Iphone 6 Plus to Note 5 the only thing i do not like about this phone is life of its battery. Is there anyway to improve it when comparing apples to apples with IP 6 plus? Same brightness, blue tooth, wifi and so on. My test show that I phone last up to 30% more when it comes to battery life.
