Terryleesv
I have the same problem but after I updated my Note 5 software, its all good fast charging every time.
I'm about to get in contact with someone I know at Samsung.
Just randomly I have been experiencing this myself, I can get it to work by messing with the charger cable by unplugging it and plugging it in several times, was fine I don't know what is causing it.
I'm having the same problem. I had upgraded to this from Droid turbo so I still had the turbo charger. I tried that and it goes to fast charge every time as where the Samsung charger I have to plug in 3-5 times to get it to fast charge. Could it be the charging unit?
If Note 5 it's the cord Mate not the other part , you need to get a thicker cord that's it, since i have the Note 4 put away the Cord From the Note 4 is Thicker than the Note 5 , Since i swiped cords it always charges Fast Charge with no issues at all!I can confirm It's the outlet. I have the same problem, unplugging and re-plugging makes no difference in one outlet. But the outlet on the other side of my bedroom, albeit inconvenient for access from my bed, Fast charging works 100% of the time, maybe it's a voltage issue, sketchy wiring on the outlet maybe?
I have the INCIPIO Ghost 100 Wireless Charging Base which I bought when I was with Verizon. I'm getting my Note 5 Monday and I was wondering will the phone work with that charging base?
