carlos12001
Turning off Google now seems to have helped my battery life out.
If you just coming from a clean install you have to at least give it a week before you start complaining about battery life.
When root/ROM was possible on the Galaxy S3/Note 2 (Verizon), just being able to root and then use Titanium Backup to freeze bloat helped extend battery life. Going with a stable and well done custom ROM like CleanROM was an even better experience for not only battery life, but how well those phones operated - lag free, smooth, and fast - like the Note 5 is now. I do miss those days.
Now I just try to uninstall or disable as many carrier or Samsung apps that I don't want. An example is the Amazon app that came with the Marshmallow update. I noticed it was using 3% battery and I had never even opened it up. Disabled that thing right away, which is unfortunate as I do actually want to use the app from time to time. On my wife's Note 5, she noticed that the "Caller Name ID" app was using up to 5% battery life and constantly popping up wanting to activate. Disabled that.
I'm charging it many times a day. But in my case it is because I'm never able to get its battery full (100%) when I charge it while it is turned on. lol, i don't even remember when was the last time I was able to full charge my note 5... I guess the 1h30m fast charge advertise only works with the phone turned off.
I was not talking about charging while using the phone. Instead, I was talking about charging while the phone is turned on, but with screen off.
Did anyone who updated to Android Marshmallow have these issues before the update or after. I know that when my husband and I did the lollipop updates it basically fried the phone including the battery life. Actually my husband has to get a new phone because after resetting and hard rebooting. Even the Verizon reps ran diagnostics and were like yup you've done it all. Come to find out it was a common issue with Sprint and Verizon versions of the Galaxy s5 ATT too.
Oh. And i just realized my phone depleted faster than usual. But i'm not sure too.
So let's say my phone at night (12am) is 100%, in the morning (7am) it becomes around 90% while data connection is on (4G).
Do you think it's normal?
A little over 1% per hour on lte depending on conditions, I'd say it's not bad. But I'd charge it overnight.
And the estimation usage time is around 14 hours on 100%.
