Hi all,
I set up my GN7 yesterday (T-Mobile) and had zero issues. I noticed the haptic feedback seemed a bit weak, but I figured it was just a setting I had to change. That said, after an hour it completely stopped working. I tried everything I could to get the vibrate function to work and had no success. So, I checked some forums and it said to go into safe mode (where you can test all the items on the device). When I would click on Vibrate nothing would happen. Some sites I checked said if it doesn't vibrate there then you have faulty hardware. I called T-Mobile and got a HUGE DRAMA runaround. Nobody knew how to get me a new Note 7 as it was so new. So, I ended up deciding to do a third factory reset (like I said, I tried everything), however this time I didn't do the "Back to Back" restore method (from my previous S7edge). Instead I did the Google restore method and just chose a handful of apps to add. Low and behold, everything worked. I set up the phone again, added my accounts, etc.
Today, I installed 4 apps - T-Mobile Tuesdays, T-Mobile, YouTube Gaming, and Google Duo. Vibrate still worked fine. An hour later I was surfing Facebook, went to tap on the "Back" capacitive button, no vibrate. W T F?! I tried everything again, no vibrate. I removed all four apps I downloaded today - no vibrate.
I'm at my wits end here with this as I am pretty convinced I got a fauly unit. Anyone have any suggestions, or do I just need to work with T-Mobile on exchanging this? My GS7 edge did not do this at all.
Thanks in advance everyone!
