So many issues with note 9
Tonche
17
First issue is with a game and mobile data.
Won't work. Apparently it's something to do with Note 9 on Tmobile networks?
I have to turn off ipv6 to connect to the game server. If I do that however, MMS stops working so no texts.
Second issue is with my Gallery. Scrolling is extremely erratic, it will suddenly zoom really fast or in reverse from the direction I swiped. When I searched for help it comes up as an old issue with something called Bixby remapper with the note 8. I never encountered that before with my Note8, and I was unable to locate a Bixby Remapper app on the note 9.
Third issue is the camera. Its... really bad.
Things like this fish end up a pixelated blur.
note1note9
325
I don't know but your fish seems ok...
RadeonHD
124
I'm waiting for this camera update everyone is seems to be getting. That's my only gripe, but being on Verizon I know for a fact I ain't seeing an update anytime soon
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,587
6,173
113
First thing first
When someone having a issue and looking for help , please help us help you . Meaning state what carrier and If device is unlocked or carrier model and what country.
Since you mentioned TMobile they have default APN setting that you can't modify so I'm assuming you added a APN and this would be the first problem. After we correct this we can proceed with the others fair?
Darth Mo
1,306
52
48
The gallery issue is probably that you're inadvertently hitting the slider that appears on the side of the screen. Pretty common with a large screen device.
Tonche
17
First thing first
Yes. I had to add a APN and I have to manually switch back and forth while on data depending on if I want to play a game or if I want to send and receive text messages.
T-mobile, locked, USA.
Tonche
17
The slider is on the right side. I use my left thumb.
I failed to mention the problem is intermittent. Sometimes it works fine after a restart.
Tonche
17
And in case some one says it's because of lowlight. 2 more shots of fish from my note 8 in lowlight.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,587
6,173
113
So when your on the TMobile APN you can't get data or text messages?
If possible can you show me a screenshot of the APN.
Tonche
17
This is default. In this mode the game does not connect to server.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,587
6,173
113
Looks the same as mine , have you tried resetting the APN , if doesn't work go to settings general reset and reset network . If still issues see if maybe try another game has same issue as I don't use games .
