Galaxy Note 9 SM-960F Not Updating to Android 10
iammoazzam
14
Hey all,
I bought my galaxy note 9 (international) back in October 2018. Got android 9 update as soon as I set up the device. I was in France and had been receiving software updates regularly. Then, I moved to Turkey in June 2019, received 2 or may be 3 updates there. I received the last software update in October 2019. I left Turkey in February 2020 and now I am in Belgium. I haven't received any software update after October 2019. Here is what I have tried so far:
>Manually checking for updates in the setting>software update
>Samsung smart switch which always says your software is up to date SI5(LUX)
>Contacted Samsung support from the app, they told me my phone is Singapore origin. I talked with Samsung support Singapore and they said that Samsung has released the update in Singapore long ago. Since I am out of Singapore and using other sim carrier so I will receive the update eventually (not really sure when).
>Using VPN proxy and setting it to many other countries just to check if that works.
>Factory data reset (I read somewhere it also works sometimes)
>Using my Turkish and Pakistani simcard (on international roaming) to see if that works.
I have tried all above things after clearing cache partition and clearing the data of Samsung store.
Is there anyone who can help me with this? or who has been facing the same problem?
iammoazzam
14
Sorry for making the same post twice. I posted first as a guest.
Anyhow, isn't there any other way to update my phone? or if you know the reason why it has stopped receiving updates?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,586
6,171
113
Hi, Welcome to AC
I'm not sure why you having trouble updating , but you can flash to latest version if you ever flashed before?
iammoazzam
14
Hi, Welcome to AC
I haven't flashed any smartphone before. Moreover, I have read on several online platforms that installing a custom ROM is quite risky. That is why I am reluctant to install one. I just don't get it why/how I stopped receiving OTA updates.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,586
6,171
113
This is not installing a custom Rom, this is flashing stock Samsung firmwares as a Samsung repair center would do.
Do you have a Samsung service center by you ?
iammoazzam
14
Oh okay. So you mean its totally safe to flash the software by my own? If yes, could you please share with me how can I do that?
and I have samsung service centre (not so close though) but its closed due to corona virus.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,586
6,171
113
I can show you little later the steps , currently at work .
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,586
6,171
113
This is the steps :
Windows computer needed
Latest Odin can Google it and download should be 3.13.1 or 3.14.1
Download samfirm v0.4.1 tool , extract it with 7zip.
You will extract files for Odin once download with 7zip and will do same for firmware with 7zip .
There will be 4 files after you extract the firmware
BL
AP
CP
CSC
Each of those files will go in Odin when you open to the corresponding slots
BL
AP
CP
CSC USE HOME CSC FIILE TO SAVE DATA
Home data slot dont put nothing
connect your phone with cable to computer , once the files are in its slots hit start, once done you'll see pass in Odin and it will reboot
My picture shows circle on what you need to do
Put your model number,region select check for updates , then download the Rom , extract the Rom with 7zip20200425_122427.jpeg
iammoazzam
14
This is the steps :
BL
AP
CP
CSC
BL
AP
CP
Put your model number,region select check for updates , then download the Rom , extract the Rom with 7zipView attachment 319693
Thanks a lot for the details. It doesn't show me the "SPR" region (see the attached picture)vdv.JPG. Can I download the firmware for another region i.e. Pakistan? or which region do you suggest? I will be using the device in Europe for may be a few more months and then I will go to Pakistan.
Moreover, after updating the software through this procedure, would I start to receive OTA updates (if there is any)? or would I have to always update through odin?
I just found this video: https://youtu.be/bnPkwICq_Bw. I will follow the same steps.
Last question, since I'll be doing it for the first time, I fear if I do something wrong. I also read somewhere that the device can brick. Could you please guide a bit about it?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,586
6,171
113
Thanks a lot for the details. It doesn't show me the "SPR" region (see the attached picture)View attachment 319694. Can I download the firmware for another region i.e. Pakistan? or which region do you suggest? I will be using the device in Europe for may be a few more months and then I will go to Pakistan.
You have to put your model and region , my picture was example
iammoazzam
14
Yeah i put my model which is SM-960F and for region I don't know. That's why I asked you that does region matter? Because I am in Belgium and after a few months I will go to Pakistan. So which region should I choose and what difference does it make?
sorry to bother you but I just don't wanna make any mistake
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,586
6,171
113
No problem
Yes the region is very important that way you can still get updates
