B buzzstar New member May 3, 2017 1 0 0 Visit site May 3, 2017 #1 It is running android 4.0, and I hear there are updates, but if I try it says no firmware sit = S2
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,602 4,751 113 Visit site May 4, 2017 #2 Welcome to Android Central! The latest version looks like 4.1.2: https://www.sammobile.com/firmwares/sgh-t989/SGH-T989/. In order to get a system update, a carrier-specific phone has to be on that carrier's network -- so if you're not on T-Mobile, it won't get the update. You could try using Odin to install it manually: http://forums.androidcentral.com/am...w-flash-stock-rom-via-odin-new-interface.html That phone is ancient, and even if you do use it on T-Mobile, I'm not sure if the servers would even bother to update the phone. But you could always try. When you get a chance, head over to the Introductions forum and tell us something about yourself! http://forums.androidcentral.com/introductions/
