My wifi on my S4 is not working, it wont turn on/enable. How can I fix this?
A
AC Question
my wifi in s4 not working, it wont turn on/enable
i tap my wifi icon,it won't turn on, i alrdy go to the settings and enabled it,but it go back to disable
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,601
4,745
113
Re: my wifi in s4 not working, it wont turn on/enable
Welcome to Android Central! Try wiping the cache partition: http://support.t-mobile.com/docs/DOC-5744. If that doesn't help, then try Safe Mode (steps are at the bottom of that article).
It could be a loose connection somewhere--if you're adventurous, you could try opening the phone up and checking (search YouTube for how-to videos).
tress
