Power button
newtda513
198
When I go to hit the power button to turn the screen then have to swipe the screen to get into the main screen. If I don't swiped fast enough it will go black again and I have to start all over again. Is this normal?
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Do you have an ability to change the lockscreen timeout? Otherwise, no, this does not sound normal.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
It usually takes around 8 seconds or so (just guessing) till my screen goes black again. Is yours on this time?
Sent from my T-Mobile Note 3 using AC Forums.
newtda513
198
I was able make it stay on little bit longer. Whee do go to change it to 8seconds
Sent from my SM-G900V using AC Forums mobile app
Almeuit
Moderator
Apr 17, 2012
32,277
23
I never changed it to that. That's just how long mine stays on the lock screen before going off (if I don't touch it).
ex2k
My power button seems abit flimsey....
Almost like a volume up and down button, it kind of goes up and down and seems loose. I thought this was a problem with the device but when i brought it back to the store and they checked another one it did the exact same thing.
Anyone else notice this? I wonder if it was the batch, I need to compare it to a device from another batch...
The power buttons on the S4 and note 3's dont do this. Has anyone else noticed this?
tress
