S7 Edge - Tempered Glass Screen Protectors
jpdaballa
346
Just Preordered by s7 edge, and i'm really hoping I don't regret it. I told myself I was going to hold off as I had the s6 (non edge) 128gb, and although the s7 edge allows a SD card i'm not really sold on the way samsung is managing it in marshmallow. Verizon offered the gear s2 with the preorder and that pretty much sold me.
To those who had the s6 edge and edge plus, should i get a tempered glass screen protector for this phone? I know that the edges wont be covered but I want some sort of protection for the screen as I generally have had luck with protecting the screen with a thin case.
Joe the Insider
Trusted Member
Feb 19, 2011
1,573
212
anon(27512)
1,933
5
Is it just me or does it look like it doesn't cover the whole screen? Looks like a pretty large gap...
Gator352
Banned
Sep 11, 2010
3,742
50
I'm wondering is that a screen shot or a picture taken off the web site? If so, why is it tilted? Top and bottom are straight, just not the screen. I guess it had to be a picture right?
norbl
8
I have never had any luck applying these so I buy them at Verizon and let them install them. However, they seem to last only a couple of months.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
It is from the zagg website linked to in post 6
felloffthetruck
Trusted Member
Mar 31, 2013
8,609
21
38
Will it actually adhere to the display or have those crappy dot matrix bumps like the Moshi's did?
You can see what I'm talking about in this video:
zipro
863
https://www.youtube.com/watch?v=c_un4DVxJro
Every single one I tried for the EDGE+ was like that. And none of them were clear, either - they all had these 'sprinkles' all over the screen. Unusable. I use a plastic one made by supershieldz for my Priv - that one has adhesive and sticks well all the way to the edges. Also doesn't smudge too easily, so I ended up ordering that one for the S7 EDGE as well. Hoping Spigen will release a decent glass one some time in the future. Just couldn't bring myself to going naked with that beautiful screen :-/
Another option would be those wet-apply ones. At least one wouldn't have to worry to get water damage on the S7 EDGE :)
jpdaballa
346
I definitely agree, you can't go wrong with zagg. That being said if zagg is taking to long to release the curved screen protector, the icroo may be a good option if others have had good experiences with them
ssiinnoojjandriod
