sfldg
My guess would be the update has problems if its updating certain packages that are disabled? I just know the app developer recommends it, not sure if there is a drawback to not enabling them
Updated. Still does not allow us to use Samsung web browser. :-\
Thanks, I miss it, wondered what happened to itIt a great browser with adblock. For some reason, Verizon does not allow Samsung's own browser to work on this phone. You can't download it from the app store.
Now that's funny.Update turns Marshmallow into Lollipop because Verizon needs to be always 3 updates behind. Just kidding.
I have noticed significantly slow fast charging, also made sure to check fast charging was enabled in settings.
S7 Edge Titantium
So, It's safe?
Does it fix the SD Card notification problem?
My fast wireless charging switches down the regular wireless charging after this wonderful update.
How's adoptable storage working for you? Does burst mode in the camera working for you after this update?Anyone thinking of doing the update and has adoptable storage enabled, I did the update with no issues.
This is what I was thinking. Likely just a dream but we can wish...I am holding off as long as possible. Seems to not be a useful update and may close a root vulnerability.
