Verizon S7 edge software update
sfldg
58
My guess would be the update has problems if its updating certain packages that are disabled? I just know the app developer recommends it, not sure if there is a drawback to not enabling them
kami8586
236
Re: Update from Verizon
I have noticed significantly slow fast charging, also made sure to check fast charging was enabled in settings.
S7 Edge Titantium
jpdaballa
346
Anyone thinking of doing the update and has adoptable storage enabled, I did the update with no issues.
Jaycemiskel
Trusted Member
Jul 28, 2011
2,769
4
How's adoptable storage working for you? Does burst mode in the camera working for you after this update?
xocomaox
2,279
I am holding off as long as possible. Seems to not be a useful update and may close a root vulnerability.
rflores5432
117
Probably a stupid question but how do you tell if the phone is charging in fast mode or slow mode?
rflores5432
117
I'm thinking that you just look under battery and the fast wireless or fast wired options should be blue when plugged in if fast charging is working. Mine stays white
Non
