Disable edge panels?
bren5666
12
Went and took a look at the S7 Edge today . Loved the looks and feel of the phone.Only issur I had was I kept accidently activating the edge panels, I honestly don't think it's a feature I would use much, so is there a way to turn the panels off? Would a case help? I know some will say to get an S7 instead but I've been spoiled by bigger screen phones and don't think I'd be happy.
bsteppuhn
831
I noticed I do think touch it more with a case on. You do get used to how you hold it. I love the edge panels
makaroni
1,209
The edged screen, edge panels, and it's functionality is kind of why you would even purchase the phone other than a bigger battery. There are other phones with expandable memory that you could choose. Some purchase it just for the looks but.... If you want to disable the edge panels, then just go for the S7 in my opinion.
Non
