Battery drains fast
yoco007
12
Hi! So I have S7 Edge for almost a month now. Great phone. Last week I got a notification for android update. I updated my phone and since then my batteries goes out in less than two days. I don't know what to do. Here're some screenshoots if it's any help. Any advice is much appreciated.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Welcome to Android Central! Your Phone Radio seems to be using the most battery. What's the cell signal been like? Show us a full day's graph of the Cell Signal graph in GSam.
It's also worth wiping the cache partition after major system updates, if issues like this crop up: https://support.t-mobile.com/docs/DOC-25076
yoco007
12
Thank you for replay. I had to charge my phone again since when I posted above I only had a few % left. I'll make a screenshoot later.
Just to be sure, cache wipe doesn't delete any kind of my stuff at all (contacts, pictures, files...)?
Venom0642
2,361
340
83
Hmm i definitely get good battery life on my AT&T S7 Edge G935A
Wizzy
239
It appears you have no data connection. The phone is eating up its battery looking for data. Do you even use the phone? 20 minutes of screen time in a day and a half? Lol!
Posted via the Android Central App from my S7 edge
optimummind
304
On my Sprint GS7E, I get great battery life if I turn off Location. With the phone set to GPS Only, it drains crazy, the number one seismicity being GpsLocationProvider_ex.
Any one else have battery issues with Location set to GPS Only? If so, plz state your phone carrier and/or model & firmware version.
I'm on PD3.
Venom0642
2,361
340
83
I'm on PD3.
As you can see above photo from post earlier my battery life is excellent on AT&T S7 Edge and i have my location always on Mobile Network and Wifi and get great battery life.
Kirk Burkhead
198
I'm on PD3.
I leave my location set on GPS only and I have no issues at all with battery drain. I'm running AT&T.
optimummind
304
How about if you set it to GPS Only or GPS+WiFi+Mobile?
Lucky. Sprint & Samsung screwed us over!
yoco007
12
Yea, I use the phone, but it's been a week off for me so now not so much.
After 24h, this is how it looks!
trexs7e
16
why is this bad battery life? your screen on is almost 15 hours? how on earth do you get that long of a battery life? seriously?
My sot is 7 hours max
johnriii
567
14
I'm somewhat confused... This is BAD battery life?? I'd kill for the usage the OP is getting... LOL.
Kirk Burkhead
198
I should state that it only activates GPS location when I use a certain app that requires it, then it turns off.
For example, if I open Maps, it will activate and use GPS the whole the app is open and being used. But when I close the app, GPS turns off. It seems that maybe yours is using GPS all the time for something?
optimummind
304
Yes, that is unfortunately what is happening with my phone since I took the April update. 😖
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
As I suspected, your cell signal is often bad. It's in the low range for about half the time (including when you took the screenshot--look at how few bars you have), and this drains the battery because the phone is working harder to keep the signal. Do you know if your signal is bad at home, at work, or somewhere else? If it's bad at home, look into getting a signal booster from your carrier, if they offer one. If it's at work, consider turning on Airplane Mode (and maybe just use wi-fi) while you're there.
yoco007
12
My phone is at my desk most of the time (when I'm not working), and signal there is only one bar. If this is an issue, why start doing this now and not when I got the phone. It's been working just fine for almost a full month!
tress
