crazyjeeper99
I'm using four languages .. no issue under android 6 .. now android 7 got worse ...as the design of icons .. they got half invisible ...
Hi guys .. same trouble and no solution found .. I type in four languages and under android 6 it worked fine. prediction was switching automatically.. with android 7 now I need to switch manually the keyboard language which is very boring ...
Only solution I could find was installing SwiftKey.
Working fine with 3 languages.. I don't know how many it can support simultaneously.
it does not work for me. Of course I input french and english but it will not simultaneously recognise the langages to correct automatically. I have to slide the space bar to swap langages: which will also change the type of key board (qwerty or azerty). I cannot write with the azerty key board with English correction anymore... it is very frustrating... anybody has the answer please?
for galaxy S7
In the settings select virtual keyboard, then select sumsung keyboard, then go to language selection and choose and download your language))))
for galaxy S7
You could try Swiftkey. I personally like it better than Gboard and can handle 3 languages simultaneously.I spoke to Samsung about this at length. They removed the functionality. As hard as it is to believe. They must have pissed off half of Europe and Latin America. I am not sure what Sasmung was thinking when they decided to take this retro step but I am sure they will be implementing it back at some point. For now Gboard is the best alternative. If it makes you feel any better, I was so upset that I decided to visit the Apple store and weight my options with an iPhone. They never heard of that functionality!! LOL. Apple lovers have been flipping back and forth for languages on their keyboards all these years!.! Unbelievable!!
