I just moved to the S9. I came from a lifetime of BlackBerry use, where I got used to the fingerprint sensor in the spacebar to wake the phone.
I often have the device sitting on the desk in front of me. I want to be able use tap and swipe gestures to wake and unlock the phone. I set the security lock to a swipe pattern to make that easy while the device is on the desk. However, it seems there's no way to use double-tap to wake the screen to even get to the swipe pattern -- it seems I have to press the power button on the side of the phone, which is very inconvenient to be doing dozens of times a day versus tapping and swiping.
And I am in business and quite security conscious, so I do need the phone to lock after 5-10 minutes of inactivity and to require a password.
I see that launchers like Nova are supposed to be able to provide the ability to use double-tap to wake the device, though I installed it and felt it out briefly and I'm really just not into all that work and modification just to get things to look "normal" just so I can add that one functionality (not to mention that I looked for it and couldn't even find it in the app, though I assume it must be there from all that I've read).
Is there really no way to use the stock settings to get it to be able to do that? My only choice is to use Nova or something similar? Or buy an S10 or Note 10 that has the fingerprint sensor on the display? From what I read, there really is no choice, but I thought I'd ask here first before doing anything drastic.
Thanks!
Thanks!
