I downloaded this when it first came out and thought it was good enough for daily use, but the lags were starting to annoy me. Then I saw there was an update to it and I downloaded it today and all i can say is "holy crap!" This is how smooth I would picture the stock rom to be when it comes out...and this is all from the sdk...amazing. Its also awesome that the actual ICS icons and roboto font have been added in!
Thank you so much guys! Theres no way I'd ever go back to Gingerbread after this.
Nope, latest update even includes Superuser.
Sent from my Nexus S 4G using Tapatalk
Yep, will be working on the ICS status bar shortly, hopefully I can get it working!
Is it not the ICS version, or is it not functioning correctly?
Thanks for the feedback.I downloaded this when it first came out and thought it was good enough for daily use, but the lags were starting to annoy me. Then I saw there was an update to it and I downloaded it today and all i can say is "holy crap!" This is how smooth I would picture the stock rom to be when it comes out...and this is all from the sdk...amazing. Its also awesome that the actual ICS icons and roboto font have been added in!
Hmm, that's weird, are you streaming the music or do you have it on your SD card?Hey guys. Things are running great but I wanted to point out an issue that I've noticed with Google Music. I've been listening to music with the ICS ROM here for the last two days and I've noticed that there are what sound like skips or hiccups when songs playback. I've even backtracked and listened to the same spots again and wouldn't hear it then so I know it's not the files. Anyone else noticed this?
The app that controls the headphone jack of a phone, that reportedly was not working.
As another fellow ROM developer, how did you manage to deodex ICS?
The current version of smali/baksmali doesn't support HoneyComb and ICS?
Also, OP, please check your PM.
Thanks.
Thanks.
anyone try to update gmaps and or google plus and get a package is unsigned error? Based on CM use, I would think that i'd have to flash a GApps package, but is there even an ICS GApps package out yet?
Myn!
Great to seE you here!
You were the evo 4g rom master back when I had it.
Would love to see what you can add to this!
Sent from my Nexus S 4G with Ice Cream Sandwich
Nope, not streaming. My music is on the SD card. Like I said, it sounds like skips on a CD but it's not actually skipping, just like a hiccup. I figured it might be an issue with the ROM since I hadn't had this problem before.Hmm, that's weird, are you streaming the music or do you have it on your SD card?
Same problem, try turning off equalizer and keeping the phone on. It may have something to do with CPU scaling and the MP3 file buffer
