3 Clicks, and I'm on 4.0.4
Got it to worked. Switch to 3G before clearing data and force stopping frameworks.
my favorite feature is disabling the automatic password lock when you press the power button... now the timeout works as expected.
4th time worked for me. Auto rotate is noticeably faster and I no longer get lag when typing on the keyboard in landscape mode. Camera response seems as fast as before. No lag. Will check 4g connection tomorrow when I wake up.
Two more tabs on the browser quick controls.
1 click cache cleaners now work.
At least I get that 3G signal. Before the update I usually just get greyed out signal at home.
The Droid Bionic I had gets 1-2 bars of 4GLTE at home, and with this nexus, still nothing. But then again Motorola makes good radio.
BAM!!!! I tried it a million times this afternoon with no luck. I hit update just now and nothing. Then I saw all these posts about it working and I tried the process one time and it worked!
Now time to see if I can force it on my xoom
Got my OTA an hour ago without me prompting anything. I dont notice any difference... maybe that the auto-rotate is slightly less laggy? =T
I used a slightly different method. I turned on airplane mode, then enabled wifi, hit check for update and it downloaded immediately.
Reactions: urabob
I downloaded the update, rebooted to install, but during the installation I get the Android with its body opened up with a red triangle and exclamation mark (I guess it failed?).
Does anyone know what's wrong? I am rooted and unlocked.
I know this is off topic, but may I ask what Live Wallpaper it is you're using?
It happened to me. I think it's because I'm rooted, had to unroot and flashed back to stock.
I did the method about 20 times yesterday did it once ten min ago and I got it
Sent from my Galaxy Nexus
This worked for me. I am a believer.
Following the instructions, It took 10 times on my Gnex and 20 times on my wife's, but we finally got the update to work and now we have 4.04 working on a phone bought on April 6th and April 23rd here in the LA area
Abheetha Athukorala
