Worked on first try!
Checked for update, nothing. Rebooted then checked again, nothing. Cleared data/force stopped the app then backed out of the screen and my phone immediately notified me that I have an update available (didn't even have to check!).
Some details (doubt it makes a difference) :
-Bought phone end of March
-Location=South Jersey
-Updated over Wifi
-Was rooted but temporarily unrooted using RootKeeper
-Stock ICS
I don't notice any significant changes. Camera may be a touch slower like OP said. Wifi signal indicator is weaker. Speedtested wifi and my download speeds were significantly slower and sporadic. I "forgot" my router and re-added it and all is well.
Update: Argh!!! 4G download speeds at my house are now about half what they used to be and upload speeds are even worse! If it ain't broke, don't fix it. If your phone was working fine on 4.0.2 I would recommend you NOT update at this time.
-Updated over Wifi
-Stock ICS
