to those that got this to work... are you guys all unrooted and stock? i got the update screen but it failed during install...
I'm not using live wallpaper! I wish it was a live wallpaper lol
Then that text is a widget?
Ok. I downloaded the update but the install fails.... Just getting the red triangle.. I'm all stock just rooted and unlocked... Now what do I need to do?
Been trying for the past two hours...
For the people who've had success, do you continuously hit the "Check now" button after the initial process? Or do you completely start over after it failed?![]()
I used a slightly different method. I turned on airplane mode, then enabled wifi, hit check for update and it downloaded immediately.
