[7.03.11][ROM] BAMF Sense 3.0 GB RC4
Flash the radio via boot loader. Save the radio to the root of the SD card and make sure you rename it first.
Still loving this rom. Battery life is the same or better so far.
Sent from my Thunderbolt (BAMF Sense 3.0 GB RC4)
getting error popup " the process com.google-process.gapps has stopped unexpectedly. I am on the MR2 radio. ? what is this?
can i assume it's safe to delete the .zip files once i've flashed them? again, this is my first rooting experience and i haven't notice this info anywhere yet.
yes you should delete them now from your sd card. I kept mine on the laptop as a backup.
I keep my down loads on my SD card with my inc without any issues. I'm no export by any means.
Flash the MR2 Radio from Clockwork Recovery and you'll be good to go.
Edit: Sorry here are the links to MR2 and MR2.5.. I'd suggest going with MR2 as it has better results from most. First link is MR2, second MR2.5
[Radio] [Leak] Official MR2 Radio 1.39.00.0508w, 0.01.69.0510w_3 - xda-developers
[Radio] [Leak] [6-16-11] MR2.5 Radio - 1.39.00.0528w, 0.01.69.0602w_1 - xda-developers
If I recall, the radio has to be installed after being renamed as PG05IMG, loaded on the root of the SD card, via bootloader....not through CWR.
I'm having an issue with the weather app stopping unexpectedly. It didn't do it when I first loaded it but its doing it now everytime it tries to update.
Sent from my ADR6400L using Tapatalk
Auto rotate working for you guys?
Sent from the Bolt via Tapatalk
Check the bottom of the original post.
NOTE: Small little glitch. After flashing the above, please install this fix to fix fcs with weather related items.
Thanks. I tried to install it but it won't install.
flash it in recovery just like you did the rom, that's how it worked for me.
SoDev, it's working for me, at least from what I've noticed (youtube app, web)
Having the same issue I was having with RC3 getting force closes on phone calls. How do I stop it?
Kudos to the das BAMF team. Had been runnimg DB 2.1, but RC4 is tempting me back to a fuller Sense 3.0 experience.
Thanks. That worked.
Sent from my HTC Thunderbolt using Tapatalk for your reading pleasure.
Is anyone else getting error messages and force closes on Phone calls? Help Please.
This is the message I keep getting:
The process com.android.phone has stopped unexpectedly. Please try again.
Reactions: dannychaos
Is there any way to reduce the number of screens to 5 vs the default 7 without launcherpro and other 3rd party options.
tour2review
