[7.14.11][ROM] Das BAMF Sense 3.0 RC4.9
If you really want to see a noticeable increase in battery life, a Gingerbread Sense-based ROM is probably not where you're gonna find it...Some ROMs may be better than others, but I wouldn't expect any drastic improvements until at the very least the kernel source is made available.
I was getting better battery life with BAMF 1.8.6 (Froyo), but I've been using this version too long to go back now.
I personally like Sense 3.0 enough to deal with the battery life, but I do hear folks claiming to get much better battery life with some of the AOSP and non-Sense ROMs.
Got ya, its almost a bad thing I experienced this then, because I dont think I would change from it either haha. Great ROM and I have not run into any problems, only slight annoyances of preference.
Did you see if it works on wifi. Before I learned of the ad blocking fix (which worked for me), streaming through wifi first would get it working over the cell network.
Sent using Tapatalk
I don't know what was causing the problem but Thanks to you it now works. Problem was solved by connecting over WiFi successfully and then connected over Mobile Network with no problem. Thanks for the suggestions and help!
Well, I thought I had it resolved. Tried to fire up Google Music this morning when I got to work and I got the FC when I tried to stream from the cloud. Back to the drawing board.
Suggestions?
Suggestions?
Well, frustuation led me to wiping the phone and resinstalling the ROM. I'm golden now.
anyone know how I can get the voice message notification to go away? I've already deleted the voice mail out of my mailbox and it still shows 1 new vm on my notification pull down n
Oh boy...I need help.
I'm a first time rooter and totally new at this. (finally pulled the trigger last night). Everything looked great. Followed tweaks and settings to get things going. Today decided to change the fonts to give it a more personal look and let the phone reboot. I am now stuck on the white htc sense screen and a battery pull didn't fix it.
Thanks.
Thanks.
Have you tried to reboot into hboot?
Pull the battery, put it back in, and hold down the power and volume down buttons at the same time. It should boot you into hboot, where you can access Recovery, where you should, if you paid attention to instructions, have a backup of your prior setup to restore to.
Reactions: phoenixone
Doing that now. Made a back up of stock rooted and stock rooted with bloatware removed. Yay for back ups. I wish there was something in red that said DON'T CHANGE THE FONTS! It will freeze your phone on the white htc boot screen. Thanks for the help. Love this place!
Sorry if it's been asked before.
Is there a My Verizon app work with RC4.9? I get "This application requires the Verizon Login Client. Please download the login Client and start the application again. Error Code-305" when I try to install the market version.
Backup Assistant gives me a network error. Is there a fix available?
When I use the camera, the last picture I took is stuck in the upper left hand corner of the screen. (wiped data, cache etc before installing rom)
Will the market update to the newer version on it's own in due time or is it not available for rooted phones?
Thanks.
Well I just decided to root again and first ROM I loaded is this one. Thanks for all the hard work guys. Runs fantastic.
Loaded RC4.9 about a few weeks back with no issues...then in the last week or so I have started getting random shutoffs...phone just goes black no response from powerbutton or screen...have to pull battery then the power button works as normal with a 7secish hold to turn on and all is good...first time it happened I thought my battery was dead...but then once I got it back on it was at 46% so that was not it...does not seem to be any paticular app...most of the time it occurs after phone has gone to sleep...as in 'in my pocket", on desk, in holder etc...then just will not wake up.
only thing that has changed in i bought two extra 1500 batteries but this is happening even when on the OEM battery
just curious if anyone else saw this with BAMF...or could it just be another hardware issue...
Try bumping up your minimum clock speed a notch. Are you undervolting the CPU? That can also cause phone shutdowns if your phone doesn't tolerate undervolting.
- Sent using Tapatalk
Thanks.
Crap...had just read this while searching for something else....then started fooling around with the tools and did the same thing...doh!!..and I must have not removed the zip from the root...now my phone wants to update when I HBOOT...aagghh...unable to connect to my phone through my comp at the moment so stuck...for now...:mad:
Wondering about the Future for this ROM... DAS BAMF SENSE 3.0 RC4.9 on THunderbolt.
When and if Verizon comes out with the stock Gingerbread will Verizon Force Push their stock Gingerbread onto my Thunderbolt with this ROM installed? Or can I keep it?
IF NOT FORCE PUSHED will I lose FREE wifi tethering? I rarely use it anyway, but have in a pinch without shelling out $30 for the hotpsot...
i just rooted my thunderbolt and installed the MR2 radio. When you say to do a full wipe before installing ROM, what does that mean? factory reset my phone? or something else?
Mine did it too with stock battery.
I'm now on preview 2.5
Sent from my ADR6400L using Tapatalk
I'm running this ROM and I Just noticed today that my Mobile HotSpot feature no longer works.
suggestions?
aravrajak
