[6.25.11][ROM] BAMF Sense 3.0 GB RC3
I got into recovery reinstalling now....thanks. What radio works best with this ROM ?
You hear different things with different ROM's... personally I loaded MR2.5 right after I loaded this ROM and have not had any issues... so no reason to try MR2 if there are no issues.
I hear ya. Even with these minor issues this ROM is sick. I love it.
Because I'm new to flashing ROMs I would love to know what all the hype is about with CM7 but I just don't think I wanna change from BAMF.
I know exactly what you mean I heard cm7 is still unstable for the thunderbolt
I installed the patch for the 6 bars and clear notications the 6 bars works but now I have a black notification bar can someone please tell me how to uninstall the patch please.
You can't really uninstall the patch - you need to make a nandroid before you flash a patch so you could just revert back.
Or you can do a new clean install of the rom without the patch.
Reactions: rob90262
Can anyone tell me if Nitro's Touchdown Exchange works with this ROM, i havent had any luck getting Touchdown to sync with my corp email . Are there any other corp email programs that work with this ROM. THanks
Thanks zero I forgot to back up this ROM so I did a clean install again you have been much help to me and everybody on this site and and it is appreciated thanks again
Anybody tried using Tango with this? My transmitted video from the TB to my wife's iphone 4 received video is upside-down. It was not like this before flashing this rom. The monitoring thumb nail on the HTC Thunderbolt appears fine.
It works. I'm using it now with this ROM.
So if I'm running 2.06 Remix - what should I flash, either 2.1 or 3.0. I just need sms and Pandora to work correctly and fast charging would be nice also.
Ok, so I tried searching for answers for this issue I'm having and I haven't noticed anybody ask about this either or if its a known issue with the ROM. About 98% of the time I'm trying to make a call, my bars drop to none the moment I try making the call and then the phone app force closes. I tried doing the force close fix and reboot and i used the MR2 but now use the MR2.5 and this issue has been the same for both times. I have done the wipes before flashing too. Any help? (And yes, I am using Das Bamf 3.0 rc3)
this is the first rom i have ever installed, any tips for a new rom user. I rooted today, put on bamf 3.0 and mr2 radio. The questions i have so far is, do you guys mess with the cpu speed and what not, and how do you install the patches. do you just put them on your sd and install the zip for them from hboot?
also, timestamp keeps getting thrown off by an hour with sms messages im receiving, which throws the whole conversation out of order.
After 3 days RC3 has made my battery in 3G twofold its self. Amazing. 4G is better then stock froyo.
Have you tried reinstalling the rom?
Sent from the Bolt via Tapatalk
RangelS25
