[6.25.11][ROM] BAMF Sense 3.0 GB RC3
One problem that has come up is, my phone turns itself off, but WILL NOT turn back on. I have to take out the battery to reset. Happens once or twice a day. Also my proximity sensor doesn't work... Any suggestions???
I've had the same problem too. Shuts down and won't power up. Have to battery pull to get back working. My prox sensor is definitely not working right. I constantly mute and end calls.
Also it doesn't display my contacts pics in the SMS messaging app. But they are displayed as my contacts.
The strangest thing I've seen is I have two contacts that are brother and sister. The brother sent me a text but in the HTC messaging widget it displayed his sisters name. Weird.
I have the CPU set on 1.024 max 245 min ondemandX governor
yes you can lol, i hadent opened that up till just now, this was my 1st Bamf ROM and i hadent had time to check everything out yet
I'm new too rooting too. I just wanted to make sure there wasn't some alternate way of adjusting the cpu settings.
yeah I can't believe I waited so long to flash this ROM been rooted for over a month.
I hear ya. Even with these minor issues this ROM is sick. I love it.
Because I'm new to flashing ROMs I would love to know what all the hype is about with CM7 but I just don't think I wanna change from BAMF.
I love sense, and cm7 is senseless. So i don't think I'll be switching. Just waiting for CM4.
<snip>
Originally Posted by RootandBoot >
To use Google voice.
Get your new number from Google.
Download the Google voice app, skip the VM setup. Choose to make no calls from Google voice.
On your phone dial *71 and your Google number (that is call forward no answer) put the 1 infront of the area code.
That's it.
When someone leaves a VM it will show on your notification bar.
Sorry for being as thick as a whale omelet, but I can't seem to make my Verizon Voicemail indicator in the notifications go away. I don't have any messages and I setup my Vmail according to RootNBoot's method. I even deleted all of my Google Voice vmails just to make sure I wasn't somehow getting the icon from Google instead of Verizon. When I call *86 to check messages, it gives the "You have no new messages" recording to me so I am sure how I am getting this indicator. I have tried uninstalling Google Voice, unconfiguring, rebooting, etc. Any thoughts?
Need Help
i rooted from stock last night and installed this Rom with MR2 radio, everything went well and the Rom is great. This morning while trying to configure Touchdown Exchange , the screen went black and came back on without the ring on the bottom, i can not pull down the notifacation bar or power off the phone. All i have on the screen is an empty background with the time , battery status and network at the top. I tried a couple of battery pulls but still no good. Any suggestions ? Thanks for the help
You need to reinstall and wipe all the cache's 3 times or more. I had the same thing happen to me and that solved the problem.
UPDATE : Flashed from RC2 - RC3 last night without a wipe and am still going without a single issue for those of you daring to try like me ;)
I had the issue without even having the radio installed so I would say try just the rom first.
Dsimppjarad
