AC Sideload Wonder Machine for Windows
Status
Not open for further replies.
o
I've got an HTC Inspire (AT&T) also. The beta runs great and says it installs. But for the life of me, I can't find them on the phone. Anyone have a clue what I'm missing?
I have the HTC Inspire on ATT too... installed the beta as instructed. I used it to install the .apk Amazon store thing....then once that was installed I went to it on my phone (it was there). So it worked no problems so the I went to download Angry Birds Rio and it downloaded but when it tried to install I got that infamous error message. So what I did after this (thanks to the guy who said to do this) I navigate to my HTC Inspire went to the android folder. Went to the folder that has amazon in its name, then in the cache folder there is a .apk file with a whole bunch of numbers. THIS IS THE GAME. So..I copied this file to my computer. Then used the SWM beta thing to install this file. It worked so I disconnected my phone went to my Applications and bam! Angry Birds Rio was there fully functional!!!
(I did it like this to get Fruit Ninja as well)
Hi,
I have htc inspire from att too. I can't get the source1.0.zip to work, can someone please post a link to their copy of aw_swm 1.0 or 1.1 on megaupload, repidshare, hotfile, etc. Thank you very much.
Hello all, I just registered for the sideload application and I wanna thank the creator of it! But I have an important question now that I've followed nearly all of the steps. Where exactly do most of you get the apps to be downloaded on your PC? And are they free?
Oh and one more thing. I've noticed a lot of people are doing this sideloading deal to get angry birds rio... but I already got angry birds rio (the game, right?) straight from the marketplace (????)... am I missing something here? (I have an at&t samsung captivate fyi)
Hi,
I was going to use sideload to load amazon.app store, recently they have daily free app that are regularly $4.99 at amazon and market.
Well I was doing some research and found the SlideMe marketplace, and also someone mentioned warez-bb.org. But then I just went to the official android marketplace and was wondering if anyone actually uses it??
Hi,
When I tried to load amazon.app store, I got this error message from swm, can someone please help me. Thank you.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\AC_SWM\payload\to_install.apk'.
at Microsoft.VisualBasic.FileSystem.FileCopy(String Source, String Destination)
at AC_SWM.frmMain.btnChoose_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
AC_SWM
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/drive/AC_SWM/AC_SWM.exe
Assembly Version: 10.0.0.0
Win32 Version: 10.0.30319.1 built by: RTMRel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
i have a motorola flip and im trying to sideload an app and it is telling me install_failed_older_sdk during the install...... what does this mean?
I am also getting an "unhandled exception" when I try to install .apk for my HTC Inspire. When I run the Diagnostics test for testing the USB driver status, I get the same report as @darkonii. When I run the Diagnostics test to test path issues, I get:
System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at AC_SWM.frmDiag.Button2_Click(Object sender, EventArgs e)
mscorlib
AC_SWM
CodeBase: file:///C:/Program%20Files/AC_SWMv1.1_10_30_BETA/AC_SWM/AC_SWM.exe
System
System.Core
System.Drawing
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
enabled.
For example:
<configuration>
</configuration>
Please help! I've wasted way too much time on this...Thanks!
Hi,
AC_SWM
See post 16, or the first post. You have the AC_SWM folder in the wrong spot. Open the zip file you downloaded, and drag the whole AC_SWM folder into your C: drive, and not nested inside another folder.
got an insufficient memory error? i have more than enough storage space on my phone, i had this running on another pc. now trying to get it to work on my new one. lil help please
error
I use windows vista. I have installed .net framework 4, installed usb adb device drivers for the samsung captivate (galaxy s). i get the error message that follows
unhandled exception has occurred in your application. if you click continue the application will ignore this error and attempt to continut. if you click quit the application will close immidiatly.
"Could not find part of the path C:\AC_SWM\payload\to_install.apk."
i get this error when i try to use either of the diagnostic tools as well and the entire swm folder is on the c drive and the apk files are placed in the payload folder.
I DONT KNOW WHAT ELSE TO DO. its driving me nuts.
this is the error i got. Failure [INSTALL_FAILED_INSUFFICIENT_STORAGE]
you said to "check file paths and that they exist."
i am not exactly sure what that means. Sorry to be a bother, but what do i do?
This usually happens when the folders were not placed in the correct place, please review Post #16
To make sure you placed the folder in the proper place.
The above applys here aswell please review your placement of your folders as instructed in post # 16.
If the problem persists, attempt to put the .apk's directly in the wondermachine folder instead of the payload folder although this shouldnt be the case try it anyway
Reactions: Jerry Hildenbrand
Status
Lassi876
