Adapt sound bluetooth problem
Hi, make sure Dolby Atmos is enabled and set to music from pull down notifications panel it helps a lot with the buds
Are your galaxy buds up to date? You could try unpairing them and doing a factory reset (on your buds, not your phone lol).
I also always recommend cycling power on your phone. "Have you tried turning it off and on again?" Is a meme for a reason.
Thanks for the tips. I have tried all your suggestions. The Only thing that helps is to turn adapt sound off which for me results in much worser sound.
But read the posts I included. Something is wrong with adapt sound after the feb update. Do you have it on and use buds? Maybe its just a few phones affected by this .
I don't use adapt sound
I was on my galaxy buds, you actually reminded me to set it up on my buds+ lol. I've not noticed any problems so far, but I'm on the march update. What specifically is the problem you're hearing?
Edit: make that the April patch... Which makes me think, are you stuck on February because you bought your phone from a network and they suck at updates?
No I'm on april from today. Problem is still valid.
Cool, as i said, what is the problem specifically? Saying you have "an issue" doesn't really help me replicate it or figure out a solution... Or are you saying you can't turn adapt sound on at all?
Bad distorted sound and the worst is that the volume goes up and down within songs.
See also the threads I posted, People with the same problems explains better. English is not my main language.
After feb update on my phone I have problem using the adapt sound when using bluetooth headphones (Galaxy Buds Plus) for music listening. My problem is similar to these:
https://us.community.samsung.com/t5...udio-quality-issues-after-update/td-p/1104974
https://us.community.samsung.com/t5/Note10/Adapt-sound-degraded-after-Android-10-update/td-p/1090240
Has anyone else the same problem in here?
I don't notice it on the Note 10. I had an S10 but I got rid of it so I don't know if it had an issue. If the software got corrupted during the update a factory reset might fix it but that might be something you're not willing to try.
NewGuyinKY
