Android 11 public beta now available!!
I did a comparison with my Pixel 3 that is also on the Android 11 beta. Same YouTube videos play much louder, so there is definitely a sound volume program on the 4XL caused by the first beta. If they don't fix in beta 2, this will be a deal breaker for me. I can barely hear the phone. I did file a bug report.
Well, it's in your best interest to report a bug problem to Google! I'm sorry to hear that though!
That's interesting, I found things got louder, especially notification and ring tones.
Notification and ring tones are fine and loud. FWIW, there's a thread on Reddit about this problem. Maybe it's only affecting certain configurations depending on carrier, apps installed, etc.
I didn't see a thread for apps that don't work with the new beta but just noticed the Android Central app crashes and does not stay open.
They had a issue, and a update in play store should fix it .
Do you use Tapatalk? That's what I use for Android central threads. No issues with that on beta. Might be something you can use in the meantime.
she come I agree with you completely here! I tried the AC forums application, however, it wasn't alerting me successfully at all about new forum postings or replies. I Tapatalk on my Pixel 3 XL Android 11 beta 1, and it's perfect.
Works fine here on my Pixel 4XL. Admittedly, I use it mostly as a reader; I rarely post replies through the app and even more rarely start new threads in it. (this reply is coming from my PC)
And, here's a reply posted through the app
P4XL on beta, question: how do I do a screenshot?
Swipe up on the swipe gesture bar on the bottom center of your screen, you'll see three options: take a screenshot which allows you to edit and crop it and then share to someone else, automatically send it to someone else, And show you all the shareable text within the application you're in.
Or just press and hold volume down + power button at the same time, probably much quicker to take screenshot that way.
I am using volume styles app which allows me to add a screenshot option to my volume button. I am using that.
kctraci1
