Android 11 public beta now available!!
Not working for me on Beta
Are you pressing and holding power button and volume down at the same time? Works flawlessly for me every time. Just tried as well to make sure.
Here is the screenshot I took by holding power + volume button at the same time. You need to hold it for few seconds for screen shot to kick in.
I stand corrected my new case covers the volume buttons and I guess I was not pushing hard enough on volume down button but it worked with no case - Thxs
Swipe up on the swipe gesture bar on the bottom center of your screen, you'll see three options: take a screenshot which allows you to edit and crop it and then share to someone else, automatically send it to someone else, And show you all the shareable text within the application you're in.
Swipe up?
Or, if you are using three-button navigation instead of gesture navigation (as I do), just tap the square icon at bottom-right (the "recent apps" icon). Besides the scrollable recent apps, you'll see Screenshot, Select, and Share along the bottom of the screen.
Swipe up?
Haha, that's one way to do it.. just swipe up if you have the gestures enabled.
So.....I was playing around last night with my home screen. Created a custom style and suddenly my phone started flashing the lock screen on and off. Nothing helped and I had to eventually put it in recovery mode and wipe/factory reset.
Well, at least I’m starting fresh now.
Oh, geezes, I'm so so sorry to hear that! Yeah when you have to do a factory hard reset that's heart-wrenching sometimes!
Just had a little scare. When I got the restart for update and pressed it, my screen went black. Disconnected from the charger and reattached, nothing happened. Thought it got bricked!
Held the power button for about 30 seconds and the G finally came up on the screen. Whew.
Ok noticed one change on my phone using Nova. Normally when I'd swipe up to get to my previously used apps they would show up normal.
Now I get a Google search bar at the bottom and apparently my most used apps. If I swipe up on that, I get my entire app list in a scrolling page.
EDIT: figured it out. For some reason I was getting both Nova and pixel launcher options happening at the same time. Restarted Nova and I no longer get that bottom part on my last apps.
baby boy
