Android 14 Stable/One UI 6.0 Now Out
On T-Mobile, S23 Ultra unlocked. Got notification this morning that update available.
Should I upgrade to Android 14 and One UI 6.0?
After I installed it, I opened the phone. It changed my home setup. I had to add back my calendar widget. The apps I had on my home screen are gone. I need to rearrange my phone the way I had it before. I never had to do this with any previous updates.
Just upgraded and rebooted. In my case it did not change home screen.
It even didn't disable Developer Options that I enabled when I got phone three days ago.
Edit.
Well, I lied. It removed finger tip scanner spot from the home page that I set up yesterday. But this was the only change after upgrading.
Well, I feel silly. Finger tip scanner spot is not on the home page, it is shown when phone is locked. So, original statement is true - upgrade did not change my home page.
We will find out
WeJaMiN
