Android 4.4.3 for Verizon HTC One M8??
I have the stock launcher, but deleted the blinkfeed page. Is it a blinkfeed update?
It's an Android update that likely has some Blinkfeed changes as well. If you're not using stock everything, you may not notice all the changes.
Just checked and found the update... it's downloading as I type.... 9% right now.
Mine is now downloading at... It doesn't matter where because updates aren't rolled out based on location.
Anyone running into battery drain like the other carriers did?
I'm sure it'll take some time to stabilize, but mine has drained from 100% to 92% in 1hr 20 minutes. After the update, I powered it off, charged it to full before powering it back on. Hopefully it's not an indicator of the future.
*Update* After the initial 8% drain, it's only dropped 3 percent in the last hour. I think it's going to be fine.
That's not really too bad. Certainly not phenomenal, but it's not bad.
Try the fixes that others have for their battery issues on other carriers. See if that helps any. Also see what's using the battery so much.
Thanks for the response.
So far the only thing I noticed changed was the addition of EPS mode, HTC Lock Screen application added, GPS logo has changed, and Do Not Disturb has been shortened to "DND".
And when you use the volume rocker it's the same color as the theme u use
I saw other carrier updates included a stock file manager to be able to move files to the sd card. I'm not seeing that on our version. Am I missing it, or were we neglected?
Got my update. Battery life in general seems great so far. Streaming Pandora and man this phone is spoiling me...
I don't have it either. I guess Verizon decided to remove the file manager just like the option to use HTC backup. :/
Couple things I've noticed. The battery usage screen under settings is more detailed now, very useful. Also one thing I don't like - my notification led is blinking when I have a text message even when the screen is on. Kind of annoying.
Nazeer zaheen
