Another new GB leak
Wait a sec, my contacts synchronized with FB for whatever reason. Never mind.
This build is way faster. The other one was a little laggy. This is really fast.
Has anyone tried the new leak in a car dock? The last leak broke that one my phone. Phone didn't seem to realize it was in the dock. I'm able to manually launch car home but that's kind of annoying.
Used go launcher since day1 , after getting update go launcher loads all the icons in a second. Seems much faster system overall . Just my 2cents. Try everything and lets find something weird.
Sent from my ADR6400L using Tapatalk
Why was my post to this thread deleted? Just because I couldn't get excited about ANOTHER pre-release leak, after a long wait? What's the deal, moderator?
Just posting this here, credit goes to "Football" at XDA but it looks like they have a new leak out, this one is 2.10.605.1. Also has a new radio. Here is the link to XDA thread:
[ROM]RUU_Mecha_GINGERBREAD_S_VERIZON_WWE_2.10.605.1_Rad io_0.01.78.0802w_3_NV_8K_1.41 - xda-developers
Also looks like a new radio. Keep in mind rooted users will loose root for good if you flash this (I think).
If anyone installs it let us know how it is.
Rooted users will be able t o regain root, but there is rooted versions of this leak out there for us.
I would recommend that you update the op with the zip RUU. The one you have there is the .exe RUU Might cause problems for some people out there. Here's the zip: [ROM] ZIP format: RUU_Mecha_GINGERBREAD_S_VERIZON_WWE_2.10.605.1_Rad io_0.01.78.08... - xda-developers
Nate44: is the process you posted in the link for non-rooted users as well?
Yes that zip is for non-rooted users. Rooted users can flash it, but they will lose root
Has anyone been able to determine if this latest release may be the official thunderbolt ota update?
They still haven't figured out the voice mail thing yet. So I'm 1000% sure it's not ;)
The download is unsuccessful every time.
Try this link: Multiupload.com - upload your files to multiple file hosting sites!
I'm not sure if it's the same md5 as the link I posted earlier, but verify the file size once finished (436.83MB)
Never say never...especially when it comes to Verizon. Look at the MR1 reboot disaster they put out officially and the GB update full of bugs fiasco on the DX that they had to fix.
So if you are rooted.and wish to be stock you can skip the normal 2 step unrest process and just flash this update?
let me guess...... I just gave myself a voice mail, checked it, deleted it, and now the icon will not go away.. Is that it... I hate that.
What force close / clear cache is it to reset the voice mail icon?
Also did anyone see tether guard in the manage applications menu? Is that new?
I am wondering the same. I am stock now too. I thought all you did was rename the RUU.exe file to PG105.zip and flash it from the bootloader...
Its PG05IMG.zip and that is what you do if you are stock and want to load an RUU. That wasnt what he asked though, he asked if you wanted to go from rooted to unrooted. I havent messed with rooting so I can't help there.
So if you're stock and want to load this, you just rename it and flash it in boatloader?
No. If your stock all you need to do is download the .exe file. After its done downloading double click on the file and it will guide you through the setup process. There is no need to rename this file to pg051img. It utilizes HTC's software, all you need to do is plug your phone into your computer with the USB cable and follow the directions.
baby boy
