Another new GB leak
No. If your stock all you need to do is download the .exe file. After its done downloading double click on the file and it will guide you through the setup process. There is no need to rename this file to pg051img. It utilizes HTC's software, all you need to do is plug your phone into your computer with the USB cable and follow the directions.
Most people reccomend using the .zip file to update from what i've seen. Just rename it, put it in the root directory on the SD card, boot into bootloader and follow the on-screen prompts. Its pretty simple. I did 2 RUUs for the MR2 updates. Its easy.
Not a deal breaker, but it looks like my contacts synced with FB have a lower resolution. Anyone have the same issue?
If you are referring to the contact picture, I have had that issue since the first time I synced FB with my first Android... Facebook always loads contact icons in low resolution.
I flashed this rom last night and man is it nice. The benchmarks are showing up sub-par but it has NO lag at all. Very smooth. No issues yet!
Sent from my ADR6400L using Tapatalk
Has the HTC flip clock issue with it being an hour behind and then resetting to normal been fixed?
My flip clock works just fine. Location is pin point on to. Are you allowing the network to set the time and date? If not, that maybe your problem.
I remember reading somewhere that this is a designed animation and not a bug.
Yeah thats designed animation.... Other wise it would just show the time and you wouldn't see that nifity animation of the numbers flipping.
there is an easy fix for his. just go into your accounts and turn off the sync for Facebook, and turn on the sync for "Facebook for HTC scenes". the HTC account brings in a lot higher res photos. hope that helps!
Reactions: msokad
I'm downloading the RUU but I'm kinda hesitant on putting it on the phone. I may just sit on it for a few days to see what everyone else is reporting on this.
Any Bluetooth issues with this build? I'm running the first build and I lose my Bluetooth connection every time I receive a text.
Sent from my HTC Thunderbolt using Tapatalk.
You Rock!! I tried that and the pictures are much better.
I have no Bluetooth issues. Was just in the gym streaming Pandora and receiving texts at the same time. No problems. I've been using 2.10 for about 4 days now.
Can someone please post a step by step on flashing this? I'm not rooted. I downloaded the .exe file then renamed it to PG05IMG.zip then placed it to the root of my SD card. Power and vol down. And this is where I got confused on what to do next. I know it sucks for the ones in the know to hold our hands through this everytime. But I really want this! Lol. Thank you all in advance..
any word on gtalk video or gtalk normal? i saw another post that said it was force closing. confirm? deny?
baby boy
