AnTuTu Test Results Are Not Good
I may have too many apps running or something. I can't get those kind of numbers. I clear cache partition and then run the test. I wonder if it's possible to boot up in safe mode or something similar, to where the minimal amount of stuff is running like on a pc, and then run the test?
Sure, Power off and hold both the volume up and volume down buttons as you press the power button. This will boot into safe mode and not load any apps except what come with the phone.
It should have SAFE MODE on the bottom left portion of the screen. Just restart to get out of safe mode. You may have to reapply some widgets.
Good Luck!
Ron
You should go in and disable some of those apps you have. Lockout Security is a waste of resources on the phone. You should disable it or uninstall it if you can.
I appreciate your response but I'm going to have to disagree with you. Lookout is awesome. When my S3 was stolen, I was able to do a complete wipe and I was able to locate the phone. Along with location information and a police report, I was able to get my phone back. Also, all of my contacts, pictures and call logs were backed up. If Lookout is preventing me from getting high numbers on that test, so be it. I'd much rather be protected.
Can't argue with those kind of results.
My best is like 48.6k. The Meizu is always #1 and the Note 4 is always #2 with me being always #3. I'm assuming the Note 4 in the #2 slot is the octo-core Exynos one correct?
My Note 4 Antutu benchmark.
Finally my 910c is back in 50k score range.
I didn't change anything. Just used normally after update to 5.1.1.
Happy again.
Sent from my SM-N910C using Tapatalk
If you want a decent score..Let the phone sit a while. Close all apps reboot give about 5 minutes. Turn off sync then boom. 54000 if that is what you are after.
I just picked up the Note 4 and so far I love it. I ran the AnTuTu app and my results are very disappointing. Power saving mode is off and before I fan the test, I used CM cleaner and their battery app to clean up any junk files and running apps and here are the results. What's wrong?
koreycabra
