Any firmware updates from AT&T on S22 Ultra yet?
Try clearing your system cache. Power down, press and hold volumn up and side key until you see the SAMSUNG splash screen. Then let go. Then use power up and down keys to select delete cache, answer yes then answer reboot and say yes. Wait until it boots up normally.
Is that the same as "Wipe cache partition"?
Yes I have all 7 security and software updates this weekend since I bought my at&t s22 ultra January two days after I went to at&t and changed my sim card and no I don't believe in coincidences.Each update will install separately one after another one.
owo Emmanuel
