Any Issues With Android 12 on Note 20 Ultra?
I had a problem with folders disappearing on my home screen after opening an app. A reboot would fix it but I ended up wiping my phone and so far no issues.
I can't get into "Recovery Mode" any more... not sure if AT&T blocked it or what. I use my normal "Volume Up + Power Button" and the thing just turns on instead of giving me my Recovery Menu, like it has since I bought it, with Android 10/11. I used to "Clear Cache" once a week, so I don't think it's me (though I haven't since I got Android 12... though, I did it immediately after the original Android 12/OneUI 4 update was finished?) Maybe of AT&T's Security Updates? (I even tried Vol Dwn + Pwr But=same stuff)
I just tried it and it worked so it's not blocked for att. The button combo to get into recovery has always been finicky for me. I've restarted my phone 4 times before I got it right.
Yep, just tried it again and it worked fine...
I have an issue with the Gallery app. Whenever I click on the share icon at the bottom to share a picture it always crash. No problem in sharing a video. It only happens for picture.
I already tried booting into safe mode, same behavior.
Anybody else have the same issue?
Hi. Wondering if you ever got this resolved, and is anyone else is experiencing it.
I've been having the same issue since the update. What's exceptionally weird is that the Gallery app in Secure Folder is the same version, but this doesn't occur there.
In the mean time, the only workaround I've found is to find the pic you want to share, then go back to the album view that pic is in. Hover over that thumbnail image with your S Pen, without actually opening the photo. The Share and Delete/Trash icons appear. Choose Share from that and it works. So odd!
(N22 Ultra on VZW)
(N22 Ultra on VZW)
Is this the Samsung Gallery App? I just tried mine and the share button works fine... I selected a folder, selected an image and clicked the share icon at the bottom - it brought up the list of "Share" options of how/where to share it to... I sent it to my email and it worked!
(N20 Ultra on AT&T)
(N20 Ultra on AT&T)
It is. I also use Simple Gallery Pro, which works fine. I do use Package Disabler Pro and am wondering if something I previously had disabled is required after the Android 12 update.
My phone is set to reboot at 3am, but randomly it boots into safe mode. This of course makes me lose all defaults. I have to re-enable SwiftKey, SMS for Signal and re-establish Nova as the default. Been since Android 12. Any thoughts or better solutions?
redmercer
