are there any disadvantages to using nova launcher on pixel 7?
The only thing I don't like about using a launcher, and I know it's silly, but I can see a difference in the animations when doing anything from inside the actual launcher.
It is very minor, but it just bugs me. I think if it could be installed as a system app it would not be an issue, but I don't root my phones anymore.
If it doesn't bother you, nova has so many more customizations that its hands down better then stock
Reactions: srgonu
Totally agree with this conclusion. Animations aren't fluid with launchers and even though I like nova, I see the change which bugs me and uninstall it.
Every android is using a launcher. It's what that interface you swipe through, click on, look at is. Even a stock Pixel is using the Pixel Launcher. On a Samsung, it's called Home, but it's still a launcher.
I don't happen to find any issues with animations. Smooth as can be, and I'm using Nova on a Samsung S20 FE.
Been using Nova Launcher Prime since the Nexus 5. I currently use it on my Pixel 7 Pro. Gestures are a amazing and the custom gestures should be standard android.
Reactions: Bkdodger1
I have my animations set to .5x always and no issues with Nova on my swipes around the launcher ...
Reactions: Chex313
I also see no discernible difference between Nova and the Pixel launcher when it comes to fluidity. If you're seeing a difference then there are adjustments that can be made with both launchers. I prefer to use native apps whenever possible. If I could remove the obnoxious search bar from the Pixel launcher I "might" use it! I have NEVER, ever used any search feature on any phone I have ever owned? SMH
And on the Pixel, the pixel launcher is a system app, other launchers aren't. Samsung Home is also a system app. Your comment is pointless, as it's not relevant to what was being said in regards to animations.
This has been written about and was discussed by a developer of a 3rd party launcher.
Just because some of you don't notice, or feel turning animations to .5 is a solution, doesn't mean others don't notice and don't want to change other settings to fix problems.
Some people don't notice the difference between 60hz and 90 hz, I do. Doesn't mean because they don't see it the difference isn't there
Reactions: srgonu
Yes. Even though I like having folders inside app drawer and don't like having Google search stick on home screen, I can't stand the experience using Nova launcher compared to pixel launcher which is system app. Even on my ZF3, I stay with one UI for the same reason. It's a small difference but I do notice in every interaction which I don't like
Your ZF3 is a horrible reference to using a non stock launcher as it isn't optimized for use on a folding device and also the fact that on a zfold the inner and otter displays are separate layouts with Samsung UI and that is not the case with a non stock launcher.
As for Nova on a pixel, I personally do not experience "lag" or any other performance issue as a few others have described. I guess to each their own and whatever works better for you is what is best.
Definitely a preference for sure …I’ve had the ZF2 and ZF3 and agree that folding phones and Nova are not a good mix ..only time I ditched Nova. .5x animations I used even with stock launchers …it’s more than enough to enjoy the fluidity … everyone has preferences so try it out and judge for yourself ..there’s no wrong or right
Unless in this case ZF3 means Z Flip 3 rather than Z Fold 3.
Ambiguous initialisation is ambiguous.
Does Nova give you an option for a better phone dialer than the standard one. I hate that it can't be full screen all the time, especially when a call comes in and all you get is a little square on top of the screen.
RangelS25
